Tips and Tricks
Share your Elsinore expertise! (This is NOT a Q&A Forum.)
It is currently Tue Jan 23, 2018 9:36 pm
PostPosted: Mon Oct 24, 2005 6:20 am
Hey there, just found the site. I have just saved a 1976 MR250 from the heap. I figured I could throw some love at it and use it to commute or hit some trails with...so a few questions for you pros...
Did it come with any lights on it?It has a "HI" "LOW" switch on the left grip.
It has a rear tail light (inoperable).
There appears to be a bunch of wires in the front that went somewhere taht the PO disconnected, was there a Speedo or tach?
Will this bike support a battery?
What is the mix ratio gas/oil?
BTW, I cleaned the carb, replaced the plug and it started on the 4th kick. I need to relace the rear wheel, rebuild the front shocks and throw new rubber on it but the bike is leak free, very clean and aside from the bent bars and missing parts, I think I'll have a blast with it!
Thanks in advance for your time, any help would be appreciated...email me or post here Ill check back asap...
Cheers
Scott
Georgia
Report this post
