Tips and Tricks
It is currently Tue Feb 20, 2018 1:38 am
 Post subject: Reed valve for MR250
PostPosted: Tue Mar 16, 2004 11:51 am
Has anybody ever put a reed valve in and MR250?? If you have any information where I can find one that will fit or one I can modify, please let me know. Thanks
Report this post
 Post subject: MR250
PostPosted: Wed Apr 28, 2004 5:01 pm
I recommend against installing a reed valve on a MR250 (if you could find one) simply because there are several things holding back a MR motor versus a CR motor. I would put a 75 or 76 CR250 motor and pipe and carb to gain more power. Might as well buy a 75 or 76 CR250 it would be easier. The MR is a fun trail bike when it is running right but for performance it not worth the mods. Compared to a CR250 it has a heavy flywheel, baffeled exhaust, lower exhaust port height in the cylinder and a much wider ratio tranny. At the minimum you would need all of the listed items from a CR250 to try to equal one.
Report this post
