Tips and Tricks
It is currently Wed Feb 20, 2019 12:57 am
PostPosted: Tue Nov 23, 2004 4:27 pm
If you have the stock 37mm Showa forks and want to make them more supple, consider this. Drill a hole with a #54 bit exactly two inches up from the base of the damping rod - the opposite of the end that screws into the fork cap. When put back together run 275 cc 5-weight fork oil. This is a recommendation from Al Baker "back in the day"...
AHRMA, CalVMX and SVRG #190
Honda CR250R Elsinore 1979
Honda CR480R 1983
Honda CR250R 1987
Report this post
PostPosted: Fri Dec 03, 2004 10:09 pm
Michael,
Does this work for all three years? I thought the 1980 forks were much improved over the previous years. Did the factory just make a modification similar to this on the 1980 forks?
J
1978 CR250
1979 CR125
1983 CR480 (x2)
1988 CR250
Report this post
