Tips and Tricks
It is currently Wed Sep 19, 2018 3:11 am
PostPosted: Wed May 05, 2004 9:01 pm
1982 CR480R
Keihin PE45B 38mm
Float level 22.5 mm
Air screw 1.5 turns out
Jet needle 28K
Clip position (not stated assume #3)
Main 178
Slow 68
Slide 3.5
1983 CR480R
Keihin PE45C (assume also 38mm)
Float level (assume same)
Air screw 2 turns out
Jet needle 28G
Clip position #3
Main 180
Slow 72
Slide 4.0
These are as stated in the factory manual.
Report this post
