Tips and Tricks
It is currently Thu Oct 18, 2018 1:59 pm
 Post subject: Countershaft Sprockets
PostPosted: Thu Apr 08, 2004 2:10 pm
I'm still using the original style countershaft sprocket with the plate that holds the sprocket on and two bolts that hold the plate on. I'm soon to need a new one but the ones that come from Sprocket Specialties are the newer style that use the circlip to hold it on. Has anybody used this style on a 73-74 CR250? Thoughts?
TIA,
Loren
Report this post
 Post subject: countershaft sprocket
PostPosted: Sun Apr 11, 2004 9:29 pm
I have a sprocket specialties counter on my CR250 1973 clip style and it works real well.
Easy to install..no problems.
Report this post
 Post subject: Counter Shaft Sproket
PostPosted: Wed May 05, 2004 9:32 am
I'm getting my 74 CR250M out of moth balls, and I noticed I need to replace the front sprocket, (several teeth are missing) Where can I get a replacement. Also I would like to drop a tooth or two in size. Any suggestions would be appreciated.
Report this post
PostPosted: Wed May 05, 2004 10:58 am
You can try Sprocket Specialties at: http://www.motorcyclesprockets.com
For stock sprockets you might check with Western Hills Honda at: http://www.westernhillshonda.com/
Loren
Report this post
